call of duty 4 alpha blending problem
Video RAM 128 MB 86.0 MB
3D Yes Yes
Hardware T&L Yes Yes
Pixel Shader version 2.0 2.0
Vertex Shader version 2.0 2.0
it says i need 512mb of ram,does 447 count? my comp says 512.
...............................................................................................................................................:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
that doesn't help, is annoying, and i believe against the rules to continuously bump repeatedly hourly.
and that tells me nothing, i mean the actual graphics card's name, go to the start button in the bottom corner, right click on computer and go to properties, then in the top left corner go to device manager, now go to display adapters and tell me what is says there.
3D Yes Yes
I'm guessing that is from the systems requirement lab. Your video card is extremely old and weak, I am guessing. Doesn't have enough video RAM, and just won't be able to play the game. If this is a laptop, then you can't upgrade your card. If it is a desktop, post the specs and/or the model of computer if it is a prebuilt one from a manufacturer.
i believe thats vista/7, i'm running xp, and i can tell you that my display adapter is SiS Mirage 3
and i have an even older laptop that can run WaW,Bo,Mw2,Mw,3,2,1,finest hour,united offensive,and so on.& 1gb of ram.
aka, that card is useless for gaming, it's also an off brand one that probably doesn't have good drivers that support this kind of stuff well enough, it's just not going to work out well for ya.
