Virtual PC need Advice
cobrahead
Good day folks! i heard and see this stuff but did not often encounter or making this Virtual PC in the past, running 1 PC set for 3 to 4 workstations. 1 set of cpu for 4 monitor, mouse and keyboards.
so now we have a project for this Vitual PC set, i am asking you guys if you ever made this kind of stuff. it will use for encoding purpose only and other papers works.
can you give me a specific instruction how to make this Vitual PC Set,. thanks guys if advance looking forward in it..
regards
virtual pc allows you to run virtual machines on one physical machine. each virtual machine acts as a standalone computer. you need enough resources to run all your virtual machines simultaneously. this is done mostly to test different OSs or programs without affecting your main system.
you don't necessarily need 4 sets of monitor/kb/mice. unless you set up thin clients that remote into the virtual machines.
if this is what you want, you can probably set up a terminal server and get better performance out of it.
sorry sir for my bad explanation, i think i wanna set up a thin clients, just one physical terminal server to run 4 set of monitor/mouse/kb any advice or step by step instructions sir?
thanks in advance am looking forward on it
You'll need an expansion card and the proper adapters to get this to work properly. Without the proper equipment, you be able to do this. I'm very sorry that I can't recall what the thing is called, but it's been several years since I've used one.
i appreciate your suggestion sir no need to sorry! and for the equipment i can managed to produce but i have no idea what equipment do i needed,
can anyone know this one? im seeking your advice.
a step by step instruction and what equipment do i needed to make this work done..
sorry for my wrong title post this is no virtual pc right?any idea what it is called?
