yo john is a 6970 or 5950 strong enough for me to push eyefinity?
For some games yes others no. Just or fun I tried to run BFBC2 2 monitors (just to try it out) in eyefinity off of my 6950 and my frames were in the 30s on 2 monitors. I doubt it would be playable on 3 without turning down the settings. Games that are less demanding will be fine with a single card. What are you playing?
For an eyefinity setup I would recommend dual cards. Preferably cards that have more than 1gb of RAM.
Thanks John
The crossfire troubles can happen with x2 cards as well. It is 2 cards that are crossfired on one circuit board if I understand that correctly. They can get some of the same bugs that happen with regular crossfire or sli setups. remember, for all the people that are complaining about the bugs that the drivers have there are more that hooked them up and have been playing happily for months. They just don't post about it.
The monitor that you linked looks fine for an eyefinity setup. Even though the bezels are kinda large you will get used to it. You will be focused on the center screen anyway.
