Shredder0103
Howdy, im having some problems with my computer. First off it is a custom built with an asrock mother board. I just recently installed a ATI6850 GPU. i did not have internet at that time so i installed the driver from the disk. This did not work for some reason so i waited till i had internet... I dont suspect a bad PSU since it is only a couple years old. It doesnt over heat or anything.
Now that i have the internet i went to install&update the GPU, my pc started up and than flashed a blue screen for a split second and rebooted. Than no matter if i try to start in safe mode, normal mode, or any other mode it just loads for a sec and reboots. Also sometimes it says something about checking hard disk consistency, than a new screen apears and it shows all this stuff is is checking in a list followed at the end by the percentage it has completed.
So basicaly i have no idea what to do. I checked the mechanics of my pc and everything is hooked up rite. I even removed the GPU and tried to start with the onboard gfx but that didnt work.
Any help is much appreciated
