Mr.Moose
Hey guys, building a new system and finalizing some of the parts before I order which should be about 3 weeks from now. I was set in for a HAF X full tower case but I literally looked it for a good minute and came to the conclusion it was too childish almost. Anyways, my hunt for a new case is on...
My first question is what size case should I get?
Specs:
CPU: i5 2600k
GPU: Radeon 6950- 2GB
Storage: 1 TB WD 7200RPM 32Mb Cache
RAM: 8 GB Corsair Vengeance
PSU: Corsair TX 750W PSU
Motherboard: Havent fully decided but it'll be a full ATX board 100% (not extended ATX)
Cooling: I plan to have an aftermarket cooler so must be pretty width-generous. I'm not sure if I want to install a water cooling system, I like expandability though so assume I'll need a case which can easily fit a WC system.
Budget: I'd like to say up to about 150 - 200 bucks?
Other info: If im paying over 150 I'd like for most of it to be steel and when we get to the 200 range I'd prefer a pretty much all steel case. I won't be majorly overclocking but still like my system to be COLD, so pretty good air cooling is a must. Or at least the ability for good air cooling.
Right now I'm assuming most of you are thinking about the 650D... So am I but I'm not sure if I want a mid tower case, and the 800D seems to be out of my price range. If you guys think that a mid tower will provide enough airflow/space then I'll get the 650D most likely but I'm still 100% open to any suggestions.
Thankyou for taking the time to read my post, and answering my questions!
Thanks!
-Moose
Specs:
CPU: i5 2600k
Thanks!
-Moose
