Hello Everyone (New Member)
petera88
Hi I am about to build my first computer and thought it would be a good idea to get involved on one of these forums. Reading through a lot of different posts I have put everything I want in a shopping cart at microcenter but before I buy it I want to make sure everything will work once I bring it home.
Here is the Rig
i7 2600k
http://www.microcenter.com/single_product_results.phtml?product_id=0354587
Corsair Vengeance Series 8GB DDR3-1866
http://www.microcenter.com/single_product_results.phtml?product_id=0355881
GTX 480
http://www.microcenter.com/single_product_results.phtml?product_id=0339329
ASUS P8Z68-V LGA 1155 Z68 ATX Intel
http://www.microcenter.com/single_product_results.phtml?product_id=0364996
950 Watt Power Supply
http://www.microcenter.com/single_product_results.phtml?product_id=0337657
Samsung SSD SATA 6.0Gb/s 64GB
http://www.microcenter.com/single_product_results.phtml?product_id=0378086
Storm Scout ATX Gaming Case
http://www.microcenter.com/single_product_results.phtml?product_id=0308296
12X Internal Blu-ray Writer
product_id=0361928
(5x) 120mm Case Fan
http://www.microcenter.com/single_product_results.phtml?product_id=0353929
I basically want to make sure everything is compatible, will work, is a good rig, and that I am not forgetting anything I need before I submit such a large purchase. Thank You guys!!
1. 950 watt psu is way overkill unless you plan on sli or crossfire.
2. You will want a regular hard drive for data storage
Have you checked to see what kind of deals you can get on newegg?
Sounds pretty cool. I'm afraid I can't share much advice (I'm new here too, and came for the same reason as you), but I did want to stop in to say "welcome!" :) Let us know how this goes as you progress.
I would get a GTX 570 over a 480. Less power and heat and about the same performance.
http://www.microcenter.com/single_product_results.phtml?product_id=0378189
EDIT: I don't think you really need 5 fans in that system. But if you want them, it's not going to hurt anything.
Not a necessity but I would put an after market cooler on the i7. I'm guessing that since you bought the k version you are looking into overclocking. If so, you will want a better cooler.
Thanks for all the input guys...sorry for the late response. I actually went to microcenter and picked up everything using the advice I read from here. I just built it and got it to post (super excited it actually worked). Minor problem with the ram I put in it not reading properly but got that squared away. Sitting at the BIOS now. Going to insert the OS disc and see what happens. :D Im super surprised it worked. When I pulled out the PSU and noticed all the cables involved I was a little nervous lol.
