Windows 7 # of Processes
pjoseph
I have a dell laptop running windows 7,
what would be an average # of processes running?
Looking at mine I have the following
Processes 75
also shows Physical memory 48%
just wondering if these numbers are considered normal, low, or high
thanks
Lets find out what processes are running.
Vista and 7 users will need to right click on the icon and click on "run as". If the run as option doesn't appear then press and hold the shift key while right clicking on hijackthis.
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Post the logfile that HijackThis produces
There are no rules wether is that high or not.That depends completely on you and the way you use the computer and number of things you are running in the foreground and in the background.I for example 99% of the time always have 63 processes running all at the same time.It's nothing bad lol I simply need them to run all the time for what I do.
If you have 75 running processes,it does not mean it is a virus immediately lol.Just take a good look at what things are running.Those you don't need,simply turn them off and make sure you make them to not start automatically with Windows unless if you need them all the time.
Like I said...there are no rules wether a specified amount of running processes is LOW or HIGH.Some computers have 20,some 30,some 60,some more than 100 and so on.It all depends on what the computer is being used for...
Cheers!
Thanks for the replies
It is a Dell Latitude e650
Windows 7 Pro
32-Bit
4GB ram
Intel i5-2520M , 2.50GHz
I will have to do the hijackthis stuff later in the week, i will post once I do.
thanks again
Running processes:
C:\Windows\system32\taskhost.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Symantec\Symantec Endpoint Protection\SmcGui.exe
C:\Program Files\Common Files\Check Point\UIFramework\cptray.exe
C:\Program Files\Pointsec\Pointsec for PC\P95tray.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Windows\System32\igfxtray.exe
C:\Windows\System32\hkcmd.exe
C:\Windows\System32\igfxpers.exe
C:\Program Files\Nuance\PDF Professional 7\PdfPro7Hook.exe
C:\Program Files\Microsoft IntelliPoint\ipoint.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Windows\System32\StikyNot.exe
C:\Program Files\ATI Multimedia\RemCtrl\ATIRW.EXE
C:\Windows\system32\rundll32.exe
C:\Program Files\Windows Media Player\wmplayer.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Windows\system32\SearchFilterHost.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://google.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = 155.104.94.210:8080
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = 169.254.1.1;*.ascopower.*;*.ascoswitch.com;*.enps.com;*.liebert.com;*.emrsn.org;*.learninglogin.com;<local>
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O1 - Hosts: 155.104.94.168 enpusfpkinf08
O1 - Hosts: 155.104.251.109 ascosw
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: PlusIEEventHelper Class - {551A852F-39A6-44A7-9C13-AFBEC9185A9D} - C:\Program Files\Nuance\PDF Professional 7\Bin\PlusIEContextMenu.dll
O2 - BHO: ZeonIEEventHelper Class - {DA986D7D-CCAF-47B2-84FE-BFA1549BEBF9} - C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll (file missing)
O3 - Toolbar: Nuance PDF - {E3286BF1-E654-42FF-B4A6-5E111731DF6B} - C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll
O4 - HKLM\..\Run: [Check Point Endpoint Tray Application] C:\Program Files\Common Files\Check Point\UIFramework\cptray.exe
O4 - HKLM\..\Run: [Pointsec Tray] C:\Program Files\Pointsec\Pointsec for PC\P95Tray.exe
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [IgfxTray] C:\Windows\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\Windows\system32\hkcmd.exe
O4 - HKLM\..\Run: [Persistence] C:\Windows\system32\igfxpers.exe
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [PDFHook] C:\Program Files\Nuance\PDF Professional 7\pdfpro7hook.exe
O4 - HKLM\..\Run: [Nuance PDF Converter Professional 7-reminder] "C:\Program Files\Nuance\PDF Professional 7\Ereg\Ereg.exe" -r "C:\ProgramData\Nuance\PDF Converter Professional 7\Ereg\Ereg.ini"
O4 - HKLM\..\Run: [IntelliPoint] "c:\Program Files\Microsoft IntelliPoint\ipoint.exe"
O4 - HKLM\..\Run: [APSDaemon] "C:\Program Files\Common Files\Apple\Apple Application Support\APSDaemon.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKCU\..\Run: [RESTART_STICKY_NOTES] C:\Windows\System32\StikyNot.exe
O4 - HKCU\..\Run: [NetSP - restore settings on power failure] "C:\Program Files\AT&T Global Network Client\NetSP.exe" -show
O4 - HKCU\..\Run: [ATI Remote Control] C:\Program Files\ATI Multimedia\RemCtrl\ATIRW.EXE
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O4 - Global Startup: AT&T Global Network Client Monitor.lnk = ?
O4 - Global Startup: VPN Client.lnk = ?
O8 - Extra context menu item: Append the content of the link to existing PDF file - res://C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll/ZeonIEAppend.HTML
O8 - Extra context menu item: Append the content of the selected links to existing PDF file - res://C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll/ZeonIEAppendSelLinks.HTML
O8 - Extra context menu item: Append to existing PDF file - res://C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll/ZeonIEAppend.HTML
O8 - Extra context menu item: Create PDF file - res://C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll/ZeonIECapture.HTML
O8 - Extra context menu item: Create PDF file from the content of the link - res://C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll/ZeonIECapture.HTML
O8 - Extra context menu item: Create PDF files from the selected links - res://C:\Program Files\Nuance\PDF Professional 7\Bin\ZeonIEFavClient.dll/ZeonIECaptureSelLinks.HTML
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~1\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Open with Nuance PDF Converter 7.0 - res://C:\Program Files\Nuance\PDF Professional 7\cnvres_eng.dll /100
O8 - Extra context menu item: Open with PDF Professional 7 - res://C:\Program Files\Nuance\PDF Professional 7\Bin\PlusIEContextMenu.dll/PlusIEContextMenu.htm
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~1\Office12\REFIEBAR.DLL
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) - http://appldnld.apple.com.edgesuite.net/content.info.apple.com/QuickTime/qtactivex/qtplugin.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = emrsn.org
O17 - HKLM\Software\..\Telephony: DomainName = emrsn.org
O17 - HKLM\System\CCS\Services\Tcpip\..\{38F87FC3-32AE-469D-B980-97465C38A97A}: NameServer = 10.16.64.11,10.20.64.11
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = emrsn.org
O17 - HKLM\System\CS1\Services\Tcpip\..\{38F87FC3-32AE-469D-B980-97465C38A97A}: NameServer = 10.16.64.11,10.20.64.11
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: Domain = emrsn.org
O17 - HKLM\System\CS2\Services\Tcpip\..\{38F87FC3-32AE-469D-B980-97465C38A97A}: NameServer = 10.16.64.11,10.20.64.11
O20 - Winlogon Notify: GoToAssist - C:\Program Files\Citrix\GoToAssist\615\G2AWinLogon.dll
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Systems Incorporated - C:\Program Files\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: Autodesk Content Service - Unknown owner - C:\Program Files\Autodesk\Content Service\Connect.Service.ContentService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: LANDesk(R) Management Agent (CBA8) - LANDesk Software, Ltd. - C:\Program Files\LANDesk\Shared Files\residentagent.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Cisco Systems, Inc. VPN Service (CVPND) - Cisco Systems, Inc. - C:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
O23 - Service: FLEXnet Licensing Service - Flexera Software, Inc. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: GoToAssist - Citrix Online, a division of Citrix Systems, Inc. - C:\Program Files\Citrix\GoToAssist\615\g2aservice.exe
O23 - Service: Intel Local Scheduler Service - LANDesk Software, Ltd. - C:\Program Files\LANDesk\LDClient\LocalSch.EXE
O23 - Service: Intel PDS - LANDesk Software Ltd. - C:\Windows\system32\CBA\pds.exe
O23 - Service: LANDesk Targeted Multicast (Intel Targeted Multicast) - LANDesk Software, Ltd. - C:\Program Files\LANDesk\LDCLient\tmcsvc.exe
O23 - Service: Intelligent Response Agent - Unknown owner - C:\Program Files\MANDIANT\MANDIANT Intelligent Response Agent\miragent.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LANDesk Remote Control Service (ISSUSER) - LANDesk Software, Ltd. - C:\PROGRA~1\LANDesk\LDCLient\issuser.exe
O23 - Service: LANDesk Policy Invoker - LANDesk Software, Ltd. - C:\Program Files\LANDesk\LDClient\policy.client.invoker.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: AT&T Network Configuration Service (netcfgsvr) - AT&T - C:\Program Files\AT&T Global Network Client\netcfgsvr.exe
O23 - Service: AT&T Global Network Client Service (NetClientSvc) - AT&T - C:\Program Files\AT&T Global Network Client\NetClientSvc.exe
O23 - Service: O2FLASH - O2Micro International - C:\Windows\system32\DRIVERS\o2flash.exe
O23 - Service: PDFProFiltSrv - Nuance Communications, Inc. - C:\Program Files\Nuance\PDF Professional 7\PDFProFiltSrv.exe
O23 - Service: Pointsec - Check Point Software Tech Ltd - C:\Windows\system32\Prot_srv.exe
O23 - Service: Pointsec Service Start (Pointsec_start) - Check Point Software Tech Ltd - C:\Windows\system32\pstartSr.exe
O23 - Service: Symantec Management Client (SmcService) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Smc.exe
O23 - Service: Symantec Network Access Control (SNAC) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\SNAC.EXE
O23 - Service: LANDesk(R) Software Monitoring Service (Softmon) - LANDesk Software, Ltd. - C:\Program Files\LANDesk\LDCLient\softmon.exe
O23 - Service: Symantec Endpoint Protection (Symantec AntiVirus) - Symantec Corporation - C:\Program Files\Symantec\Symantec Endpoint Protection\Rtvscan.exe
End of file - 11313 bytes
Is this a business laptop? Your hosts file contains an ip address from new york, but I see you are from california. If this is a business pc, we can't help. You need to contact your network admin for support.
