Need help quick!!! Need to buy today!
S4Laurent
Hello all.
Straight to the point. Im buying a new computer and i want to make sure everything is compatible and works properly. And its all the components i need for a new build. ( My 2nd build sorry for noobie question )
Thanks!
Video Card:
EVGA 02G-P3-1569-KR GeForce GTX 560 Ti 2Win (Fermi) 2GB 512-bit GDDR5 PCI Express 2.0 x16 HDCP Ready Video Card
Motherboard:
EVGA X79 SLI 132-SE-E775-KR LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Proccesor:
Intel Core i7-3960X Extreme Edition Sandy Bridge-E 3.3GHz (3.9GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73960X
Proccesor fan and adaptor:
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel
COOLER MASTER RR-ACCY-2011-R1 Intel LGA2011 Retention Bracket for Hyper 212 EVO & Hyper 212 Plus
Model #:RR-ACCY-2011-R1
RAM:
G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL9Q-16GBZH
HARD DRIVE:
Intel 320 Series SSDSA2CW160G3K5 2.5" 160GB SATA II MLC Internal Solid State Drive (SSD)
CASE:
COOLER MASTER CM Storm Series Trooper (SGC-5000-KKN1) Black Steel / Plastic ATX Full Tower Computer Case
Extra case fan:
COOLER MASTER SickleFlow 120 R4-L2R-20AR-R1 120mm Silent operation Red LED case fan
I have a 1000w power supply unit and the OS already.
where are you buying this from and for what? many of those things are most likely pure overkill for any and everything you plan to do.
looks absolutly solid to me, other than you may want to get a 1tb hdd for storage.
Also what is your psu? i presume its a good make but no harm in checking.
Its a BFG EX Series 1000w.
Also scratch that title. I need help in general. I was to afraid to make the purchase that day w/o help from you guys. As the SSD should even do that. I heard they are pretty unreliable. I was looking at the kingston hyperX ssd's those any good?
Oh, and am i wasting unnecessary money here?
Heres my current build.
Proccesor - QX6850 Intel Extreme
Video - GTX 295
RAM - 8GB DDR2 800MHZ
Motherboard - Evga 780i sli
I currently can't run BF3 on the highest settings which gets me really frustrated. I can run it on medium w/o any problems. If i put it on high i can occasionally lag when lots of explosions are going around.
Anyways what i want is, a computer that will run games on the highest settings at least for a year and a half from now. ( I can always upgrade the graphics card after)
well that stuff is a little on the dated side, and that gpu isn't really that fast compared to the newer high end ones.
I'm no expert but it seems as though you want this for gaming so there's no need for a 1000 dollar hex (12 with HT) core processor unless you are running HEAVILY multithreaded applications which I'm assuming you aren't from your posts. It seems you mainly want a gaming PC, the difference between your CPU and a 2500k/2600k when it comes to gaming would be nothing. Assuming you want to spend the same amount of money which really isn't necessary for your needs.
You could get this combo which would be able to play almost any game on the highest setting for more than the next year and a half: (They're are only the main components)
GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127574
CPU:
http://www.amazon.com/Intel-BX80623...rocessor/dp/B004EBUXSA/ref=dp_cp_ob_e_title_1
MoBo:
http://www.amazon.com/GIGABYTE-GA-Z...WTJC/ref=sr_1_1?ie=UTF8&qid=1322443097&sr=8-1
Originally your Mobo/CPU/GPU combo would cost around $1800
What I recommended costs about 1150 (just these components) and gaming wise would be faster than your original build. You could even go for a 3GB GTX 580 and still be fine for Bf3 amongst many other games.
Now, I don't know you nor do I know what you intend to do with your machine. If you plan to do some crazy high resolution 3D renderings or video editing, sure go for your original build as it really is an amazing build that is extremely powerful. From your posts though it seems you're more focused on gaming/virtually no video editing/rendering etc. and in which case getting the combo I suggested will give you better performance at a lower price in games.
I'm rambling, yes your build is compatible.
PS: A friend of mine was similar to you, he was tired with his slow computer/performance in games ended up buying a 500 dollar graphics card to play WoW and Counter Strike Source (OVERKILL)... You'd be surprised at how powerful high end graphics cards are becoming
