why? So you can see the games at a minor glimpse of what they can be. Xbox is limited to DX8.1 and with a ATI custom GPU. most games out today wont even play on a DX8.1 system (back in the Raedon 9600se days I think, maybe Geforce 3?) This just holds back the looks of a game. But hey, you could probably hack a 360 to run OSX 10.5 easier than a PC since its running a tricore PPC processor.
It is a tweaked DX9 on a 360, not DX8
Yep, and the
graphics is about the same as a 3 series nvidia chip. Laughable.
Essentially an XBOX is a pentium III based machine with Windows 2000 and a series 3 nvidia GPU. Pretty old and rubbish these days.
For only about $250 you can get a LGA1155 mobo and Core i3, which will make all of your computer much better.
And that is an Xbox, not a 360, the 360 is running a cut down version of a 3000 series card, giving the performance close to an X1950, or equivalent to our now budget video cards.
@bratos:
It is cheaper to buy a PC for gaming when you factor in the price of games, the price of subscription (in the case of Xbox) and for the functionality you get.
If you drop ~£400 on a system, that will be able to play all games out now on High - medium settings, which is essentially one above the quality you get with a console, assuming the game isn't a direct port.
Then, assuming you buy an average of a game a month, you are saving ~£10 per game (£45 for a console, £35 for PC on release, with preowned/deals generally giving the same difference), that is £120 a year. When you consider new a console is ~£300 (again for 360, PS3 you have already spent the £400 and then some), you are now £20 up.
Second year, £140 up, giving you money to upgrade to keep on the top settings. This pattern continues, but the difference at that second year is you have spent the same money, have the same number of games, but have a better quality of gaming on the PC thanks to better graphics, quality and community, where as your console counter part is now running on what was already dated technology.
To OP:
what is your budget for this system, instead of asking for just parts, we can tell you what the best you can get will be
