Need help!
thelolman123
So I'm building my gaming PC for $801 + Warranty/Shipping. Now I looked up how to build it, etc. all that kinda stuff. Now I just need help knowing what parts are able to overclock, if the parts will fit, and if they're compatible with each other. (Note that I am going to put in 2 Radeon HD 6870s) I really need help quick guys! Thanks!
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145299
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138318&nm_mc=TEMC-RMA-Approvel&cm_m
mc=TEMC-RMA-Approvel-_-Content-_-text-_-&AID=10521304&PID=4166869&SID=jpis3z7lywm4
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231394&nm_mc=TEMC-RMA-Approvel&cm_m
mc=TEMC-RMA-Approvel-_-Content-_-text-_-&AID=10521304&PID=4166869&SID=1osak29i8gcs7
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119213
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=422166&CatId=5432&
;SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&AffiliateID=je6NUbpObpQ-7mSMkJwD3xb
CPNCRCRp9og
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521
Now I know these are a lot of links, but I really need quick help! Btw my friend might put it together for $40 because even though I looked at helpful video, I gaurentee myself to **** it up.
How about getting the haf 912, going up to 8gbs of 1600 for 40 or 30 if any are still on sale, and go down to a quad core since nothing benefits fram six and get the 965 or 960t. Then get something more like the xfx 650w or tx650 from corsair which can power a single 6970 which will be a little slower but more reliable than the 2 9870's. Then go to a samsung or western digital or seagate hard drive. Also don't forget you will need a os or the whole build will basically be useless.
Can you link some? I would be really grateful if you did and I've only looked at this kinda stuff based on the videos I saw on good gaming comp parts. But plz link the parts you described, I got the HAF 912 though (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233)
Sorry but on iPod right now but someone else prob will help ya out. You can just search them on newegg right now and look.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150517
http://www.amd.com/us/products/desk...d-6670/pages/amd-radeon-hd-6670-overview.aspx
Those are what you were talking about? And how do I install an OS (The basic idea) Thanks a huge bunch!
Yep and for the os you have to buy the disk which costs 100 then you stick it in and boot and it loads the disk and you start downloading it similar to downloading software off of any disk.
Thanks! You're a big help and I've got 2 more questions.
1. If I get that case, then it doesn't come with any fans which wouldn't it overheat the PC?
2. I found the perfect graphics card! XFX HD-697A-CNFC Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
And just to make sure, these are all compatible right? (Like the whole build)
The haf 911 has fans, idk why they don't list them or whatever. But otherwise it looks good but did you change the pay, the other is decent but it's a cheeky one and is t very powerful.
The Haf 912 case comes with 2 fans, one rear fan and one front fan.
Quoted from newegg..
Cooling System:
-Front: 120 mm fan x 2, 1200 RPM, 17 dBA (one is optional,can be swapped for one 200mm fan)
-Top: 120 mm fan x 2 or 200mm fan x 1(optional)
-Rear: 120 mm fan x 1, 1200 RPM, 17 dBA
-Side:120/140 mm fan x 1 (optional)
I have this case and its great. It has lots of room for higher end video cards, has a dedicated rack for 2 ssd drives if needed. Will move some air if you add the 200 mm top fan. I love this case.
Oh thanks yea I noticed :D But with all that I listed, with the HAF 912 and
http://www.newegg.com/Product/Produ...na&AID=10521304&PID=4169961&SID=11q8eidt4upbl
http://www.corsair.com/power-supply...d-650-watt-high-performance-power-supply.html
Are they all compatible together? If they are I can get building ^^
yeah, i was on my ipod and typed psu and it changed it around, but apparently you did from that last post so all looks good :good:
