Cannot open Desktop Icons (XP). Help?
laffy2
All of a sudden I can't access websites from my desktop icons. When I double-click the icon an error message comes up that says: "Windows cannot open this file. To open this file Windows needs to know what program created it...".
I tried a system restore and it will not restore to any of the previous check points. I even tried restoring the system to an earlier point in Safe Mode and it did not work. Any help?
P.S. I am a tech newb.
Start scanning your system for malware.
1.
Download and run EXEHELPER.
This may help you to open programs correctly.
2.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Thank you very much. This seems way over my head, but I can try. Dumb question: I ran my Webroot scan for malware, root kits etc. and the scan does not note any threats. Is this the same as what you're suggesting below?
1.
2.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Every program scans for different things. I would highly suggest you follow through with my advice and run the scans. New malware comes out on a daily basis and unless the manufacturer of the programs stays up to date on stuff then the program won't catch it. Run the exehelper file to see if you can run programs normally again. If you can, then run malwarebytes and hijackthis.
I get a warning from Trend Micro when I clicked on EXEHELPER saying it is a dangerous site...
