Is it possible, yea. Is it safe, no.
The non K versions can only be overclocked via the FSB, and overclocking the FSB on the sandybridge processors is not stable. You will only be able to get a few hundred MHz at most.
can i overclock my i7 quad core 2600?
It's safe, just as long as you don't go crazy with high voltages and clock speeds.Is it possible, yea. Is it safe, no.
Jamebonds1 old mate
eocf represent
you upgraded to that 250 yet?
the safety aspect is assuming he has the stock intel cooler. On stock, no OC, even 10MHz is safe.
is that under load, or at idle?
ok. Fair enough.
But I will still never recommend a OC on stock cooling, even if stock is LN2.
