Hi Folks,
New guy here. Having problems getting in to pcper.com so thought I would join your board. I am visiting my daughters in St Louis who has major problems with her pc. Really need some help getting it fixed.
I don't know how to get some of this done. This is a post of the issue and my step by step. But I think it can be done much easier.
Her drives C and D are SATA. And I do have Acronis 2012 on the machine. She is running WinXp SP2. I want to make the D drive (with image of C) into C bootable. I realize at some point I will have to switch SATA 1 and 2 connections.
Here is my feeble plan. But I'm sure you folks have better ideas.
My plan
- Make an image of my C on external drive with Acronis (backup software)
- Install Acronis 2012 to my D
- Do a restore of Image to D (now I would have an image on both drives
This is where I am stuck. I was thinking of formatting C (if that can be done) and renaming it to Z. Then rename D to C (but it has to be bootable). And lastly rename Z to D.
I don't know if you can format an active drive, but the new C would be bootable.
Sure hope this explained my issue enough. Basically I want to switch drives and format original C:.
Thanks for all assist you may offer.
Swen
My plan
Swen
