Upgrading graphic card
kemkoi
Hello my current graphic card is an Gtx 550 ti fabric (oc) to 970 mhz and i am wondering if it is worth to get the sapphire radeon hd 6970 2gb i am a hardcore gamer! i will get bf3 soon also my power supply is a powersupply at 500 w it's may a bit to low...
why do you always post to that site, it really sucks, every time i've looked newegg stuff was much cheaper, in this case, 100 bucks less
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121429&Tpk=ASUS ENGTX580 DCII/2DIS/1536MD5
or for 550 there is a 3gb version which if you can afford it would prob be worth it in the long run
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130655
but like strangle said, the 7970 is just around the corner and for 550 it performs a good bit better than the 580
Yea for sure, i should wait a bit , to see how good 7970 performance the new 600 serie's , should come out soon , maybe i should wait, until 7970 come out and then go for 6970 in crossfire mode the card should get cheaper a bit ^^ :)
