Sorry I made a post like this already, but I lost it somehow
. Anyway I was going to build a desktop, but I'm kind of too impatient at this point to spend awhile researching(since I know nothing). So I think I might take the easy way out and just buy a desktop that can run SWTOR perfectly for the cheapest price. Any suggestions would be awesome...
I copied and pasted the "minimum requirements" for the game:
Processor:
AMD Athlon 64 X2 Dual-Core 4000+ or better
Intel Core 2 Duo 2.0GHz or better
Operating System:
Windows XP or later
RAM:
Windows XP: 1.5GB RAM
Windows Vista and Windows 7: 2GB RAM
Note: PCs using a built-in graphical chipset are recommended to have 2GB of RAM.
Star Wars: The Old Republic requires a video card that has a minimum of 256MB of on-board RAM as well as support for Shader 3.0 or better. Examples include:
ATI X1800 or better
nVidia 7800 or better
Intel 4100 Integrated Graphics or better
DVD-ROM drive – 8x speed or better (required for installation from physical editions only) Internet connection required to play.
Here is another list of "recommended" requirements I just copy and pasted:
Pentium Dual Core G6960 2.93GHz
Phenom II X3 B75
Login
GeForce GTX 465
Radeon HD 5850 1024MB
Login
4 GB
Win Xp 32
DX 9
15 GB
I don't want it to just get by or lag a little. I'm looking for perfectly smooth gameplay so I'd assume the specs would need to be higher than what the "minimum" suggests.
I was just looking around on newegg and came across this http://www.newegg.com/Product/Product.aspx?Item=N82E16883229285 which I haven't looked into at all, but the details on it seem pretty decent, although once again I know NOTHING lol and the price isn't bad. So would something like that do the job? More/less? Help is always appreciated, thanks!
Processor:
Operating System:
Windows XP or later
RAM:
ATI X1800 or better
Phenom II X3 B75
Login
GeForce GTX 465
Login
4 GB
Win Xp 32
DX 9
15 GB
