turbodiesel
i read somewhere on the internet that if you have a usb flash drive you can make it bootable
like just plug it into a computer and it will boot not install a OS and you use the OS on the computer until the drive is unpluged of the pc is powered off and while the computer is used you can install software and then when you plug the drive into another computer and boot it it will have the same software you installed
i would love to know if that is even possible and if it is how to
cheers
cheers
