It's perfectly ok to you a power supply with a higher amperage rating so long as the voltage is correct. You don't want to go lower though, you'll damage the power supply with extended use.
And in some cases, the laptop itself. A customer had a highly underpowered PS on an Acer Aspire and it fried both the charger and the laptop.
Regardless of whether or not the laptop is charging the battery, it will only draw as much current as it requires, period. That's why you want to have a supply that can deliver AT LEAST the current specified. Any additional current capability will simply not be used.Yes this increased amperage does matter because unlike a standard PC, a laptop requires battery charging. That is what the amperage figure is refering to. It will cause battery damage and increase fire risk, however this only applies if you are intending to use the battery.
If this laptop is a desktop replacement, and therefore not moved (no battery required), remove the battery and it will work fine.
Excess amperage will not cause battery damage unless the charger circuit in the laptop is faulty, which is causing over charge of battery.Yes this increased amperage does matter because unlike a standard PC, a laptop requires battery charging. That is what the amperage figure is refering to. It will cause battery damage and increase fire risk, however this only applies if you are intending to use the battery.
