"VISTA" says its the ANTIVIRUS
leonarskeatts
I AM posting this from my phone. My laptop has caught a bug that makes a POP up "Vista AntiVirus" says I have several viruses already. I unplugged from the net immediately. I once earlier tried to plug back in but was stopped by the "AntiVirus". Is there any sign or relative indication of a possible answer...?
Follow this. You'll want to run RKill as soon as the machine starts so you can nip the infection in the bud.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
Vista is a virus....................... Just kidding, follow those instructions and you will be fine.
When you download the software you want to click save and save it to the thumb drive then plug it into your computer and run it form there.
Check.
I went throught that process. Seems my comp won't allow it(multiple programs) to run.
You need to run RKill on a fresh startup to inhibit the virus from running (Rkill.scr should work good). Then you can install MalwareBytes.
this is from the second time i ran the quick scan. sorry I deleted the first one bef
Malwarebytes Anti-Malware (Trial) 1.60.0.1800
www.malwarebytes.org
Database version: v2012.01.13.03
Windows Vista Service Pack 1 x64 NTFS
Internet Explorer 7.0.6001.18000
ThunderLips :: THUNDERLIPS-PC [administrator]
Protection: Enabled
1/13/2012 12:22:38 PM
mbam-log-2012-01-13 (12-22-38).txt
Scan type: Quick scan
Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
Scan options disabled: P2P
Objects scanned: 186243
Time elapsed: 7 minute(s), 49 second(s)
Memory Processes Detected: 0
(No malicious items detected)
Memory Modules Detected: 0
Registry Keys Detected: 0
Registry Values Detected: 0
Registry Data Items Detected: 0
Folders Detected: 0
Files Detected: 0
(end)
Yeah I see the quick scan didn't find anything. Are you also sure that you have the latest definition database?
I clicked on "update" and it said successful.
The codes are from the second time I ran the quick scan. The first time it found 32 infected files. alot were from "temporary internet files" which i'm thinking is cookies. the full scan has been going for an 1hr:43mins now and has found 3 infectinos
Protection: Enabled
1/13/2012 12:37:06 PM
mbam-log-2012-01-13 (12-37-06).txt
Scan type: Full scan
Objects scanned: 444165
Time elapsed: 2 hour(s), 54 minute(s), 4 second(s)
Folders Detected: 0
Files Detected: 3
C:\Users\ThunderLips\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\55\37b99e77-49916b6f (Trojan.Agent.H) -> Quarantined and deleted successfully.
C:\WINDOWS\assembly\temp\kwrd.dll (PUP.BitMiner) -> Quarantined and deleted successfully.
C:\WINDOWS\assembly\temp\U\000000cf.@ (Trojan.Agent) -> Quarantined and deleted successfully.
(end)
I find it odd that's all it found. Let's kick this thread around and wait for John to come in. He's better at helping users than I am.
I doubt you deleted the first malwarebytes log you did as they are saved within the program. Open malwarebytes, click on the logs tab and open the first log for the scan you did that found all the infections and copy and paste it back here. Also, still need to see a hijackthis log.
