novicegeek
Hi there. Can anyone help me with a problem? I have two computers hooked up to one printer through a router. About every month or so, it will not print and it says there's no device driver installed. I've found out how to fix it, but I really want to know what's causing it (and how to make it stop).
To fix the problem, I print out a network page from the printer and check the IP address. It's usually changed from ...1.2 to ...1.3, or visa versa (that's the last two numbers, of course). I will simply go into printer properties, create a new TCP/IP port using the lastest IP address on the printer and it works fine.
Can anyone tell me what the heck is going on? It doesn't take long to fix, but being a novice geek, I'd really like to know what's happening behind the scenes.
I'd appreciate any help. Thanks.
