CFCs such as R12 and R22 haven't been used commercially for a while. Their HFC replacements, such as R134a, are most common now. "Freon" is really a trademark of DuPont and their refrigerants, but people often use it as a synonym for "refrigerant" similar to Kleenex and "facial tissue".Can you even get freon anymore? I thought (H)CFCs stopped being sold.
What exactly are you planning on doing? What type of system? How cold?Sepzis said:Well i'm building a freon cooling system for a PC build. I'm wondering if freon cooling on the CPU will damage the motherboard in any way? gonna use a asus maximus IV extreme-z MoBo. Also any tips on where to get decent liquid cooled ram sticks?
Well I was thinking about using freon, because i actually have freon at my disposal. The main question is. Will the low temp endanger the MoBo's durability? And for the ram sticks and other parts, i was thinking about using aftermarked LQ cooling, like exos, or something.
if you do that route you will have to ensure your mb is properly insulated from condensation. again no reason to cool the ram if this is going to be a 24/7 rig.
Not sure what you meen by 24/7 rig. I'm looking to overclock to the max. This rig is ment to be a bit overkill.
I would argue that "freon" (still not sure which refrigerant you're referring to) is relatively easy to acquire. What you're planning to do with it is the question.Sepzis said:Well I was thinking about using freon, because i actually have freon at my disposal.
Are you saying that phase change and "freon" cooling are different?ScottALot said:24/7 rig meaning you can turn it off/on as you please like a regular computer. Usually this title is only available to those who air cool, water cool, phase change, or TEC cool. Freon doesn't seem to be viable for 24/7 use.
Even if that is the case, that doesn't necessarily mean much.Gary1 said:Apparently OP works with Air conditioning or something????
And that question has been answered: As with all sub-ambient cooling, condensation must be accounted for. Otherwise, it is doubtful that any other thermal issues would arise.Gary1 said:I don't know where he is getting it, or how he got it. His question was Does he need to protect his motherboard and how??
As opposed to the non-cold kind? So him having R134a, boiling point at 1 Bar of -26C, is the same as having some R14, boiling point at 1 Bar of -128C? Regardless, I would have more confidence in him knowing what he is doing if he knew what type of refrigerant he had and how he was going to use it (single stage? cascade? what compressor?). So yes, instead of answering his question I am trying to gauge if this is time wasted on everyone's part. To the OP, Sepzis, I apologize if you do have a vapor compression system in mind and have experience with refrigerants, but your statements don't lead me to believe this. Having refrigerant on hand is typically the least of your worries.Gary1 said:I am sure he is talking about the kind of Freon that is cold, and I am sure it's not important to know what he has.
No, I'm an engineer and I work on things much colder than HVAC systemsYou've probably been asked this before, but are you an HVAC tech or something Yeti?
No, I'm an engineer and I work on things much colder than HVAC systems.
Yeah, I've followed that site off-and-on for many years. A lot of incredible systems on there including that 5 stage cascade.just a noob said:Anyway, what do you think about this? http://www.xtremesystems.org/forums/...rmany-!/page21
Yes, you need to protect against condensation. There are two goals to this:Gary1 said:I would like to know do you need to do something to protect the MOBO?? If so how??
When thinking up a system, I would recommend starting with your goals - what do you want it to do (temperature? potential loading? running 24/7?)? Then you can choose a compressor, refrigerant, etc. that will accomplish your goals.Gary1 said:And as for the Freon I will be using what ever A) is installed in phase change, or B) someone more qualified than me to purchase. Sorry for being short but I am not concerned with Freon until I know what I am doing with the components I do have. Honestly If I go ahead and get someone to make this for me and it crashes my mobo and CPU then I have to start over.
Sure, its a good idea if you want to heavily overclock your computer and you have the necessary money, time, and patience (or just lots of money).Gary1 said:Also it would be nice to know if its even a good idea.
