Memory comes from nowhere
Goatmasta
Recently the amount of space on my hard drive has been freeing up with out me deleting anything? Why is this happening? Do I have some kind of virus?
Are you missing programs or something that would account for the missing memory?
If not, then I would say that it could be defragment freeing up space.
memory means storage space. It can be used to refer to the hard drive (nonvolatile memory) or RAM/cache (volatile memory).
Defragging doesn't free up hard drive space. It moves related bytes of files closer to each other so it loads faster.
Sounds like a malware problem. Hopefully johnB will find this.
what I was thinking is that if there was space that was taken up by programs that were deleted, then the defrag might throw the data to the end f the drive and represent it as free space? Just an idea though.
Once a program is deleted, from the recycling bin or uninstalled, it should be recognized on the hard drive as free space right away. I still think its most likely malware or someone's on his/her computer without them knowing.
Well, usually malware/viruses will take up more space, not remove data from a drive. The OP isn't giving a lot of information to go on here, like how much data is gone from one day to the next.
To Goatmasta
If you think you could be infected then do the following.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
When the hijackthis log appears in a notepad file, click on the edit menu, click select all, then click on the edit menu again and click on copy. Come back to your reply and right click on your mouse and click on paste.
