Need a nice decent graphics card please
4RealzDiego
My Atm Rig:
Intel Core i7-2600 3.40GHz (Turbo Boost 2.0 up to 3.80GHz)
Processor Main Features
64 bit Quad-Core Processor
Cache Per Processor
8MB L3 Cache
Memory
8GB DDR3
Hard Drive
1.5TB SATA Green Product - variable RPM
Optical Drive 1
16X DVD±R/RW SuperMulti Drive
Graphics
AMD Radeon HD 6750 Graphics Card with 1GB of Discrete Video Memory
Im looking for a graphics card with 2Gb Video Memory
what's your vid card budget though? and what are you going to do with this, gaming still doesn't require over 1gb, i don't think anything needs over 1.5gb's, and just getting a 2gb card doesn't mean it will perform better than your current card
ok so your computer already comes with a 500watt power supply and it also has a AMD Radeon HD 6750 1GB video card, i don't think anything needs upgrading.
A OEM 500W probably only has like 300/350W on the 12V rail. Plus its a cheap built unit and can only do that at max for a short period of time.
Its his computer and the 6750 is only a low/mid grade card. The lowest end part in his computer and his power supply. If he wants a better video card, who are you to tell him he doesnt?
He said his price on a power supply is between 100 and 150 bucks. So like what jonnyp11 said, we just need his price limit on a video card.
To the OP, If you're looking to upgrade you're gonna have to do the PSU to support the new video card. So what ever your budget it was for a video card add about $100-$150 for a PSU.
That post from 2 days ago he probably forgot about and didn't re-read or anything, he slipped up, everybody does it
