IE is not working.
I made this post here earlier than explains my problem:
http://www.computerforum.com/207899-please-help-my-network-problems.html
My internet provider wont help me either.
So now I will just try to update win 7 manually, if not a smart person knows how to fix this.
Here is a copy of an email I send to a person regarding the problem:
I tried many things and I followed the advices like u see in this link:
http://www.thewindowsclub.com/how-to-fix-network-internet-connection-problems-in-windows
I remember I reset the winsock manually and that I changed something in TCP4? or something like that ( network settings)
After I did that I could go online again but only with firefox. IE and Chrome and other browsers dont work. And also I cant download any win7 updates. Error code: WindowsUpdate_8024402C
There is also not possible to download any updates to many programs, but still there are a few programs that can be updated online. Usually I get a error message that says that there might be something wrong with my proxy or that my firewall is blocking. I am quite sure that my firewall is not the problem. I use win 7 firewall and I cant see that this firewall blocks the programs. Have also tried to turn off the firewall.
When I do a diagnosis in IE I get the error message: windows could not automatically detect this networks proxy setting.
I have done a virus search and everything seems normal.
I have also update my network cards drivers.
I suspect the problem is something with the proxy or internet settings?
Do u know the solution to this problem?
Computer:
Desktop. Amd. win7.
MS Windows 7 Home Premium 64-bit SP1
AMD Phenom II X4 965
ASUSTeK Computer INC. M4A88T-V EVO (AM3)
Some addtional info:
Network
You are not connected to the internet
Computer Name
NetBIOS Name JANFREDRIK-PC
DNS Name JanFredrik-PC
Domain Name JanFredrik-PC
Remote Desktop
Console
State Active
Domain JanFredrik-PC
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout 60000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout 30000
IEProxy Auto Detect Yes
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Disabled
File and Printer Sharing Disabled
Simple File Sharing Enabled
Administrative Shares Disabled
Adapters List
Realtek PCIe GBE Family Controller
IP Address 146.247.221.26
Subnet mask 255.255.240.0
Gateway server 146.247.208.1
Network Shares
No network shares
