what computer do i need?
neon mouse
i need something for higher end gaming ive got around £600 to spend. i need one that has higher than the following. - Microsoft Windows 2000/XP/Vista/7
- 1.0 Ghz Pentium 3/4 or AMD Athlon/64 compatible processor
- 256MB system memory (RAM)
- 750MB free, uncompressed hard-disk space
- ATI Radeon 9600/NVidia Geforce Ti4200 with at least 128MB memory
- Microsoft DirectX 9.0c or higher
- CD-ROM/DVD-ROM Drive for installation
Here are a few links to companies who custom build systems.
http://www.pcspecialist.co.uk/view/Vortex-500-gaming-pc/
http://www.meshcomputers.com/Default.aspx?PAGE=PRODUCTCONFIGPAGE&USG=PRODUCT&ENT=PRODUCT&KEY=990615
http://www.meshcomputers.com/Default.aspx?PAGE=PRODUCTCONFIGPAGE&USG=PRODUCT&ENT=PRODUCT&KEY=998620
Although just to say, you would be far better and cheaper, if you can find a private system builder in your area who can custom build a pc for you, that way you can hand pick each component and you will get a proper retail windows disc.
That's nearly 1200 dollars. You can get a fantastic computer for that.
Those requirements are VERY low.
So almost any computer that is halfway modern will work.
