Hello! I am thinking about building my own PC for the first time. In the past I have bought them factory made, but I've only realized that it is much cheaper to build it yourself.
I am looking to play games such as Battlefield 3, not necessarily at Ultra settings, but that would be desirable.
I just want to make sure everything fits and is compatible. I have done some research but I just want to make sure. I do not know whether I overclock or not, so I am not sure if I should choose i7 2700 or 2700K. Any advice?
Graphics Card: XFX AMD Radeon HD 7970 Double D Black Edition 3072MB GDDR5
Hard Drive: SeagateBarracuda 7200.12 2TB 64MB Cache Hard Drive SATA 6 Gb/s 7200rpm - OEM
SSD: Corsair Force Series 3 120GB SATA 6Gb/s SSD
Processor: 2nd Generation Intel® Core™ i7 2700K 3.50GHz Socket LGA1155
RAM: Corsair Vengeance LP 16GB (4x4GB) DDR3 PC3-12800 C9 1600MHz Dual Channel Kit
Cooler: Noctua NH-D14 *2011* Dual Radiator CPU Cooler
Case: Coolermaster HAF X Case - Black
Disk Drive: Samsung S222AL 22x DVD+/-RW SATA Black Lightscribe - OEM (I do not wish to burn or play Blu Ray DVDs.)
Sound Card: Asus Xonar DX
Motherboard: MSI P67A-GD53 Intel P67 (Socket 1155) Motherboard
Internal WiFi: Not yet chosen. Advice?
OS: Windows 7.
Did I forget anything?
Thank you!
EDIT: Power Supply: Corsair Professional Series AX850 80PLUS Gold® Power Supply
OS: Windows 7.
Thank you!
