single gtx680 heaven 3.0 benchmarks
Juggalo23451
[UT]A0YS2bdxBvg[/UT]
[UT]tyYcqXAf1fg[/UT]
Overclock settings I used on the 680
1.025 volts
+100 gpu off set
+500 memory off set
+132 power set
2cd run oc settings
1.115 volts
+150 gpu off set
+510 memory off set
+132 power set
3rd/4 run Oc settings
1.125v
+175 gpu off set
+515 memory off set
132 power set
minimum does matter as much or more as the average. at 12 FPS, you are going to be getting severe lag. Just think of it like this. 2 seconds you jump from 0 to 100 FPS. Your average is 50 FPS. however for 1/2 of the time you have a solid image, no FPS progression.
you also have to keep in mind this is a benchmark as well.
So, what's the difference from BF3 to that? that has a scripted camera motion? But BF3 has random explosions and all. So in BF3 you would be looking at more drops wouldn't you? although BF3's engine isn't as harsh as unigine i don't think, since it's made to stress it to its max, but still.
