Yes the CX500 will have everything you need, and so will the CX600. They both even have 2x 6-pin power connectors so if you end up buying something like a GTX 275 in the future that requires two 6 pin power connectors then you should be OK.i will take a look into it, i am guessing it comes with all of the connections i will need? and all the wiring? :/ im unsure on PSU's i don't know much about them at all and thanks for the advice![]()
No you can't.byteninja2 said:I can power a 560 with a 380 watts by seasonic.
Good point, in which case the OCZ ZS 650W is pretty good. I've got one and it has 1x 6-pin connector and 1x 6+2-pin connector - the 6+2 can either be 6-pin or 8-pin.mikeb2817 said:you may want to look for something with an 8pin connector.
Honestly, 400w is enough. A good one though, not a cheap one, I can power a 560 with a 380 watts by seasonic. Antec, OCZ,SILVERSTONE, SEASONIC, and Corsair are very good, antec is okay to great.
