Penguin738
i have decided on a build to run WOW and minecraft. Is this a good build for under 500$,do i need to buy any other parts/connectors/wires, and is everything compatible?Also, should i OC any of them?
-cheap dvd burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244
-HEC Blitz Black Steel Edition ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121096
-SeaGate Barracuda 250gb hard drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148765
-basic usb wifi adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16833180079
-sapphire radeon 6670 (the ddr3 version)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102952
-Coarsair builder series 430W 80 plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
-g.skill 8gb 1333mhz Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
-biostar h61mgc motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138332
-Intel Celeron 2.4ghz dual core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116409
-windows 7
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
-cheap dvd burner
-windows 7
