hey everyone. this is my first post on here. i'm looking to buy a new desktop pc and i'm hoping you guys can help me out with picking which one is best for me. yes i know that building your own is better/cheaper but that's not an option right now so please don't tell me to just build one.
besides basic internet surfing, i'll be using this computer mainly for music production. the DAW that i'll most likely be using is ableton live 8. so this computer needs to be able to run that(or just a DAW in general) and also needs to be able to handle a decent amount of tracks, vsts, etc. i don't plan to have a TON of tracks and vsts running, but i'd like this computer to be able to handle a decent amount of them.
based on my budget(can't spend more than $400), these links below are to some desktops that i've found that, to me, seem to have everything i need. i just can't figure out which one would perform better for what i need. so, can you guys please help me figure out which one of these would be best for my needs?
links:
1 - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1753301&CatId=4928
2 - http://www.newegg.com/Product/Product.aspx?Item=N82E16883103420
3 - http://www.walmart.com/ip/Acer-AM3470G-UW10P-Desktop-PC-with-AMD-Quad-Core-A6-3620-Accelerated-Processor-4GB-Memory-500GB-Hard-Drive-and-Windows-7-Home-Premium-Monitor-Not-I/19714387#Item+Description
4 - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1709367&CatId=4928
5 - http://www.shopping.hp.com/webapp/shopping/computer_can_series.do?storeName=computer_store&category=desktops&a1=Starting+price&v1=Under+%24400&series_name=p6t_series&jumpid=in_R329_prodexp/hhoslp/psg/desktops/Under_$400/p6t_series
to me, the $350 HP would be ideal since it's the cheapest, but if you guys think that it wouldn't perform well enough for what i need then i probably won't get that one
thanks to anyone who helps!
links:
