Battlefield 3 Thread
Ankur
It is common if your server filter gives you too many server list, I think if >10 then the ping is not shown.
linkin
At the server browser screen,is anyone else not seen all the different servers pings?
very annoying,Its every server on the list for me
Yes that happens to me.
Anyway, post patch thoughts...
Stingers/IGLA's are useless
Bipods on LMG's are too damn accurate
Grenades have too much splash damage/radius is too big
The F35 is still a hunk of junk and has a broken HUD
Any underbarrel attachment gets the damage of the main gun and the affect of laser pointer/heavy barrel/silencer/etc
You can still fall half a metre onto some rocks and suicide
They haven't fixed a whole lot of bugs (see below)
They keep changing weapon balance and core game mechanics every damn patch (stingers, explosives/mines etc)
Bugs that still exist:
Can't run over anyone in a mortar
US side tank on davamand peak rush only comes with the main cannon, doesn't "remember" your loadout
Camouflage settings still don't save properly (ie you have to check your appearance menu for the camo to stick throughout the game)
Can still fall 1m onto a rock and die from full health
You can still ride the MAV
Battlelog still sucks (why can't I go straight from the main login page to my favourite servers? Why do I have to click multiplayer first?)
Shane
Super Moderator
The fall damage is still very annoying,I cant understand why such a little problem has not been fixed yet,Same with the random suicides when jumping out a jet.
I wish they would increase the damage to tanks for the SMAW & Javelin,They seem really week compared to the RPG-7.
Aastii
I wish they would:
1. Make the Javelin a 1 or 2 hit kill on a tank, at least have the first disable it
2. Make the heli/jet rockets (not heat seakers) do more damage
3. Introduce a plane with a co-pilot
4. Fix the damn "you died, unlucky"
Ankur
I would like them to have co-pilot too, also I wish there were bombing of areas, like air strikes and fire supports.
Did anyone see when you are flying a jet, when you press c to change view (seeing the whole jet), then again press c (back to normal aiming mode) there is a wild movement or vibration? that makes my gameplay lag and also I miss the target. This is mostly when I am flying across to find a tank below to kill and when I come back to normal mode that time there is such a wild vibration that I cannot control my jet and then "Bad luck"
linkin
I've had that before, having a low ping and the network interploration slider on about 1/8th helps a lot.
Ankur
Yo, just wanted to discuss some issues I'm having at Caspian border, I am not able to survive much in tanks, someone from the jet or chopper always kills me. I think some kind of missile from chopper gets me just in one shot. I don't know why but fro only 1 shot? That is bad, I used to dominate in tanks but no more, these air attacks are good, but not these kind of. Let me get this straight, I see that vehicles especially tanks and AAs aren't much of strong as they are quite vulnerable to these air attacks, jets aren't too scared of AAs and choppers just eat up tanks.
mrjack
You are probably referring to TV missiles. According BF3Blog, this was one of the things that DICE changed in a recent server patch. It shouldn't be a 1-hit kill anymore, but then again the patch release notes also say that AA missiles have been fixed even though they haven't (LevelCap's video on this).
Ankur
I hope they fix that problem soon, I am just playing infantry in big maps, really BF3 seems switched from a vehicle game to infantry game.
Ankur
Anybody having issues when map is changing?
I basically play maps in which the map rotation is off, when the map rotation is on the map changes fine, but only once, when the map then changes to another map the second time, I crash out of the game. IS anybody having the same issue?
linkin
Oddly enough, I never have many map loading issues. The only one I get is that sometimes I get the black screen with no flashing dot down the bottom, but I have BF3 on the SSD so loads times are good.
SuperDuperMe
Iv had this problem a few times last couple of days.
claptonman
So don't ask why I want this... but does anyone have the "friday fun fun fun" dogtag? Can I join a game and take it from you by, you know, stabbing you in the back?
Apparently you can't wear stolen tags?
Ankur
Hey guys I think this will be fun.
Post your BF3 graphic stats, just go to www.bf3stats.com, search your player name on the search bar on the left, when you find your then click graphics in the bar where you player name is located.
Select your favorite graphic and post it here. Please post a maximum of 3 graphics stats.
Here are mine,
Ankur
Oh you guys have K/D and W/L ratio more than 1, hmm will have to work on that.
Here is my Air force stats.
