about to check coolers, you still got any of those other cards? (wasn't it you with the 295 and stuff?)
this might seem like a stupid question, but for someone buying it, couldn't they use like a 80mm or so fan over the cooler and either weld or zip tie it down?
 easier fix than any of the solutions...
 easier fix than any of the solutions...Not for running 100% wide open 24/7.a good 550w should do fine
...could probably contact msi and see if they have fans avaliable for iteasier fix than any of the solutions...
I got a 600 watt OCZ modstream. Would that work?
Not good enough then.it will max at 504 watts on the 12 volt rail. I am not 100% on it though.
Your cpu is what 95w? Then add a bit for other things.
You need to leave some head room.
