wolfeking
banned
Huhh? She said, Doesnt Seem to hard...
I said basiccly that is hard, just try picking it up and you will see
And 87dna said thats what she said? No, she didnt say that.
It was a sex joke kid.
dont know whats going on
Ahhhh.....
Lets divert this conversation to how awesome my pc is.
but the other convo is so much better. And no offense, but your PC is not really all that great. It will do what you need, sure.
Yeah, you are the one saying that.
Where here did I claim mine is great?Yeah, you are the one saying that.
His CPU is still better, even with your over clock.I would be suprised if your cpu is better by a lot than mine, when mine is oc 600 mhz than yours.
Mine is going to be upgraded soon to be a low budget kick cheese machine, and now its a extremly low budget casual gamer. Im sure less budget than yours, mine cost $300 including monitor! I would be suprised if your cpu is better by a lot than mine, when mine is oc 600 mhz than yours. And than you bring your psu into this If my psu was the same wattage as yours, it would be slightly better.? And, you say the box says 4870 is better than a 260 , because its not something amd would say to get you to buy the amd instead of the 260, right?
His fsb is 1066 stock, even with your overclock you can't hit that speed.
couple of things.
1. AMD did not say it. VisionTek said it. And they would rather sell Nvidia as it cost more. And there are numbers to back it up. http://www.tomshardware.com/reviews/radeon-hd-4870,1964-7.html
2. Mine is 500 and that is with all new parts minus the HD4870. Go back and buy yours brand new and with parts that would actually have some quality (the case) and be able to run what you wish to upgrade (PSU) and I would almost guarantee that you would spend the same.
3. Again, since you seem to have dodged the question. Where did I claim mine is great?
4. Comparing the C2D E8400 (speeds that you have yours overclocked to) to the G530, the 530 ties (slightly higher, but not enough to notice the difference) http://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Core2+Duo+E8400+@+3.00GHz
5. Again, I did not say mine is great. I no where claim that. You said yours was, burden of proof is on you. I show my numbers.
Literally no cable management at all. Quality is design, not just how much steel it can be made from and how far it can be dropped. By that logic, if I dropped phone off the table and it broke, then it would be low quality. Drop a man off a 20 foot bridge and he breaks, he must be low quality.
And as far as price, If I dropped to a 160GB Maxtor and 4GB of RAM, It would be a lot cheaper indeed.
I'd like to see a cpuZ screenshot of that.My fsb is 1333, I believe, higher then 1250 definitely.
