Video card
Truestateofmind
Hello all,
I have a amd anthlon 64 x2 5050e, on a ecs iris 1.0 motherboard. My current video card is an onboard card a nvidia geforce 6150e nforce 430. I want to play the new diablo but I need a better card before I can do so. So my question is whats a decent card I can get thats compatable with what im currently running and will still be decent enough to put into a new setup when i upgrade. Thanks much
Budget?
Personally, I would wait for lower end kepler cards, (6XX sries), but if you need it now, I would get radeon for new features.
Hi end
http://www.provantage.com/evga-02g-p4-2680-kr~7EVGA0NX.htm
Low-Hi End
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130782
Mid end and below, nvidia doesn't make kepler cards for yet.
Med Hi End
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131464
Med-Low, older, but not very
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
Low-Hi
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102967
Low, not reccomended (really, the lowest price that will play most games okay)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125403
Hate to say it...but high end cards will be severely limited by that cpu, id go mid range at the highest...with plans to change CPU + Mobo + Ram to get more out of the gpu.
If its anything like WoW, its going to want some cpu to back it up, but yes a mid range card should handle it okay.
-looked at the system requirements, may want a upper midrange card to get a good experience, seems a bit on the heavy side in terms of comparing to wow...its a different animal i suppose
so you think ill need a new power supply if i add a video card?
It's depends, what came with it? I saw a Site with that motherboard, and it came with a Compaq, so if it came with a compaq, you will need a new power supply. So, your budget should be $160 for a pretty good setup, $150 might be to little.
