Enermax has good PSU's. I had a 720w that ran 5870 Xfire and an I7 860 at 4.2ghz for months.
My sleeper, gotta upgrade graphics card from a 1gb 9500 gt.
I think it looks pretty good actually. What would you upgrade to? Seems like you've got a fair bit of room in that case and a decent power supply.My sleeper, gotta upgrade graphics card from a 1gb 9500 gt.
It's looking good Wolfe, so you got your motherboard back from RMA then?got some updated pics. will have to update again tomorrow when the VGA-DVI cable gets here so I can install the 4870.
Oh yeah I remember you saying how you didn't like the H61 board.wolfeking said:no. Its in Dallas, TX on its way out to the CA newegg office. So at a minimum it will be 5 more days, probably more. The motherboard I am using is a H61 that I got on ebay for $35.
Looks good Dragunov! Your cable management isn't great as you said, but then again the case doesn't allow for cable management really - you may wanna zip tie all those cables up and then somehow put them behind the 3.5" drive bays...
Idk a gtx 560 or a 7 series radeon right now I need to buy a cd drive because mine is IDE and im using the port for the HDDs, and because of a lack of funding, im suck with the 120gb and 60gb IDE drives. That leaves $60 lol.
You can getting DVD burner for 20 dollar. Don't trust LG DVD burner because mine two of DVD burner had problem. ASUS is only 20 dollar from amazon.com or newegg.com. ASUS is good DVD burner.
Exact opposite for me. My Asus took a dump and I've built 6-7 machines with LG dvd burners with 100% success rate.
