Help getting new card!
spirosx
I've been struggling to play games like WoW and TF2 for years with this shitty video card, and now I want to play diablo 3 but I'm not about to struggle through the 8 FPS I get in it!
I need a new video card, any suggestions? All I want is to play Diablo 3 and other not super high demanding games at a comfortable level. My price range is about 100 dollars but honestly the cheaper the better. I just want something to run it comfortably until I get a laptop around next winter.
I really don't want to buy a new power supply, but if I REALLY have to could you guys also help me out with that?
Specs:
Vista 64 bit home premium
HP Pavilion a6702f PC
AMD Phenom X3 8550 Triple-Core
4GB RAM
500GB HDD
NVIDIA GeForce 9100 <--- causing the problem right now lol
300W power supply <----- also could be a problem :(
and this is my motherboard
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01421635&lc=en
Thanks for any suggestions
You are deffinatly going to need a new power supply, so bump up your budget to $160, $60 for great power supply, $100 for gpu, but please up it to $190, 130 for gpu, 60 for power supply, that $30 extra will give a big jump. newegg.com/Product/Product.aspx?Item=N82E16814102967 I wont even give you a $100 gpu, they mostly are not good. newegg.com/Product/Product.aspx?Item=N82E16817139027 Great psu.
You might not need to go that high. Here is what I recommend.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127571
You can also move down to a GT 430 if you wish. Performance will not be monumentally different but I would probably go for a 440 over a 430.
The 2 that byteninja2 recommended will beat out what I have here so it is up to you as to what kind of money/performance you want to get.
Edit: What resolution are you playing at?
If you must stay at $100, this would be better than a 440 for the same price.newegg.com/Product/Product.aspx?Item=N82E16814127605&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Video+Cards-_-MSI-_-14127605 Though my other reccomendations would kick the cheese out of this.Use the same corsair 500w.
You are still at $160 but you mentioned staying at $100 in your post. :confused:
If you can in other posts please make the links clickable. Just hit enter and put it on a new line. It makes it much easier to navigate.
Hmm, this is a little bit out of my budget :\
This is interesting, something I could probably do. And I'm not sure, does the resolution matter?
You'll run into a CPU bottleneck if you go much above 90 bucks or so.
What does that mean? :/ Sorry I'm not really tech savvy
Also, what specific specs make a graphics card good or bad? Like what am I looking for in a graphics card? I know for power supplies its the wattage though
Oh and my friend recommended me these:
http://canadacomputers.com/product_info.php?cPath=33_442&item_id=026725
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150540
Thoughts? Thanks for all the help so far guys.
Sure. When the computer processes graphics, the main processing section is the GPU. The CPU also processes data.
When you have a good graphics card but not a good CPU, the CPU will take longer to process the data than the graphics card. It will be running at 100%, while the GPU might be at 40%. The CPU is said to be bottlenecking the GPU, as it is holding back the processing of the data.
The same thing can work the other way, with a really good CPU and crap GPU.
Your processor isn't brilliant, and if you spend $300 instead of $100 or so, you won't see any benefit.
Although of course I could be completely wrong and someone else will have to call me out on it.
Right. I'm not too worried about this though since I don't plan to spend over $100 on a card anyway :p
Yeah I'm strapped for cash though like if i can just buy the 520 and run it on my psu it could hold me over till I buy a laptop next winter season.
This would be optimal for me. Question is, is it safe to run on a 300w?
