Slow my Notebook
Santuz
I have format my computer is 100%. but why my computer running slow and sometimes freeze a few seconds. I have used TDDSKiller and no one is detected.
my spec:
AsusTek K42F
Processor: Intel Core i3 M350 CPU 2.27GHz (4CPUs)
Memory: 878MB RAM Memory
Page File: 860 MB used, 1264MB available
DirectX 9.0c
I have installed all the drivers and after format. I install only Ms. Office, Foxit Reader. and IDM ..
Can someone provide a way out of this problem?
I feel like using a computer with 126MB RAM :(
What operating system are you using? If Vista or windows 7 then you need more memory installed. Get at least 4gb of ram installed and you'll be fine.
im using Windows XP Pro XP3.
cause i dont like win7.
al least 1GB RAM for XP and another Application running good
It could be a hardware issue, but not sure what exactly. Could be hard drive, ram, or something else.
Are you sure all drivers are installed correctly, even the chipset? How was it running before the reformat?
yes im sure. check from my computer - click right - manage - device manager. then i dont see anything ? Symbol
already reformat twice and same
