Suggestions on upgrading desktop to gaming PC HELP
Aeonarial
I will post my specs here: Operating System new – server roles System Model
Windows XP Media Center Edition Service Pack 3 (build 2600)
Install Language: English (United States)
System Locale: English (United States)
Installed: 9/8/2006 5:19:33 PM Gateway T6420 100
Enclosure Type: Desktop
Processor a Main Circuit Board b
2.20 gigahertz AMD Athlon 64
64 kilobyte primary memory cache
512 kilobyte secondary memory cache
64-bit ready
Not hyper-threaded Board: MS-7207G 100
Serial Number: 5C24634188
Bus Clock: 200 megahertz
BIOS: American Megatrends Inc. 080012 11/15/2005
new USB Storage Use in past 30 Days (mouse over last used for details) new Hosted Virtual Machines (mouse over name for details)
Last Used
Generic USB CF Reader -- drive 2, s/n 2004888, rev 1.01 5/30/2012 6:37:39 PM
Generic USB MS Reader -- drive 4, s/n 2004888, rev 1.03 5/30/2012 6:37:39 PM
Generic USB SM Reader -- drive 3, s/n 2004888, rev 1.02 5/30/2012 6:37:39 PM
Generic USB SD Reader -- drive 1, s/n 2004888, rev 1.00 5/30/2012 6:37:38 PM
None discovered
Drives new – drive encryption Memory Modules c,d
200.03 Gigabytes Usable Hard Drive Capacity
183.66 Gigabytes Hard Drive Free Space
LITE-ON DVDRW SHW-1635S [Optical drive]
Novatel Mass Storage USB Device [Optical drive]
Generic USB CF Reader USB Device [Hard drive] -- drive 2
Generic USB MS Reader USB Device [Hard drive] -- drive 4
Generic USB SD Reader USB Device [Hard drive] -- drive 1
Generic USB SM Reader USB Device [Hard drive] -- drive 3
ST3200826A [Hard drive] (200.05 GB) -- drive 0, s/n 4ND181CB, rev 3.03, SMART Status: Healthy 896 Megabytes Usable Installed Memory
Slot 'DIMM0' has 512 MB
Slot 'DIMM1' is Empty
Slot 'DIMM2' has 512 MB
Slot 'DIMM3' is Empty
Local Drive Volumes new – volume encryption
c: (NTFS on drive 0) * 195.25 GB 181.08 GB free
d: (FAT32 on drive 0) 4.78 GB 2.59 GB free
* Operating System is installed on c:
here is more simple- its from can you run it
CPU
Minimum: Intel Core 2 Duo E6600 or AMD Phenom X3 8750 processor or better
You Have: AMD Athlon(tm) 64 Processor 3400+
Upgrade Suggested: Unfortunately, your CPU does not meet this requirement. Click here to see some recommendations.
CPU Speed
Minimum: Info
You Have: 2.2 GHz
RAM
Minimum: 2 GB
You Have: 896 MB
Upgrade Suggested: Unfortunately, your RAM does not meet this requirement. Click here to see some recommendations.
OS
Minimum: Windows XP/ Windows Vista / Windows 7
You Have: Microsoft Windows XP Professional Service Pack 3 (build 2600)
PASS
Click here for the latest Windows drivers.
Video Card
Minimum: Shader 3.0 or better 256 MB NVIDIA GeForce 8600GT / ATI Radeon X1950 or better
You Have: GeForce 6100
Upgrade Suggested: Unfortunately, your Video Card does not meet this requirement. Click here to see some recommendations.
Click here for the latest Video drivers.
Features: Minimum attributes of your Video Card
Required You Have
Pixel Shader version 3.0 3.0
Vertex Shader version 3.0 3.0
Dedicated Video RAM 256 MB 384 MB
Sound Card
Minimum: Yes
You Have: Microsoft UAA Function Driver for High Definition Audio - Realtek 880/860
PASS
Click here for the latest Sound Card drivers.
Free Disk Space
Minimum: 16 GB
You Have: 168.7 GB
PASS
buy new pc
ok, i recommend buying a whole new pc... these parts are old and the newer things almost use nothing of it anymore...:(
Agreed
Your computer will barely meet the min requirements for game no matter what you do to it other than replacing everything. If you max out its potential now, it might last you a year in gaming with low settings, then you'll be completely screwed for anything new and have wasted all that money, while you could just get a new computer now.
also if i might add.
That's what sucks about technology, is that its constantly being update weekly,if not daily
that computer is probably 8 yrs old, the processor is from 03, wouldn't call that weekly. And phenom II's and core 2 duos which are ~4 yrs old are still great for gaming, and a 8800 series which is 6 years old will still play any game out with decent settings.
