compatible?
You need a much better power supply. Get a Corsair CX 500 power supply.
I Googled 'Eric Iris 1.0' and it came up with nothing. What make/model is your board exactly? So long as it has PCI Express x16 or 2.0 it will work just fine with your bard so long as you get a newer power supply.
Ok I found this info on my mobo. http://www.newegg.com/Product/Product.aspx?Item=N82E16814131397 I'm still a little confused as far as this being a pci express 2.1 video card, vs a pci express 2.0 or just pci express. does that make a difference? and i did a voltage test on what kind of psu i need it suggests a 430w http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023 should this be fine? Thanks
Part / Feature
Specification / Support
Motherboard description
Motherboard manufacturer's name: ECS MCP61PM-HM
HP/Compaq name: Iris-GL6
CPU/Processor
Socket: AM2
Supports the following processors:
Athlon 64 X2 with Dual Core technology up to 4800+ (up to 65 Watt TDP)
Athlon 64 up to 3800+
Sempron - All
Front-side bus (FSB)
2000MT/s (2.0 GT/s)
Chipset
NVIDIA GeForce 6150SE nForce 430
BIOS features
Keyboard combination to used to enter BIOS: F10
System BIOS core brand: Award
Form factor
Micro-ATX: 9.6 in X 9.6 in
Memory
Dual channel memory architecture
Four 240-pin DDR2 DIMM sockets
Supported DIMM types:
PC2-4200 (533 MHz)
PC2-5300 (667 MHz)
PC2-6400 (800 MHz)
Non-ECC memory only, unbuffered
Supports 2GB DDR2 DIMMs
Supports up to 4 GB*
32 bit PCs cannot address a full 4.0 GB of memory.
NOTE: *Actual available memory may be less.
Expansion slots
Two PCI
One PCI Express x16 graphics (for graphics card)
One PCI Express x1 (for cards such as network, sound, tv-tuner)
Video graphics
Integrated graphics using nVidia GeForce 6150SE
Up to 256MB (with 512MB or more system memory)
Also supports PCI Express x16 graphics cards
NOTE: Either integrated graphics or the PCI Express x16 slot are usable at one time; they are not usable concurrently.
Parallel ATA
One 40-pin UltraDMA 100/66/33 connector
Supports PIO, multi-word DMA modes
Supports two PATA disk drives on one PATA ribbon cable (two drives total)
Serial ATA
Two SATA connectors:
SATA1 = Black
SATA2 = White
NOTE: Each SATA connector is the same color across different manufacturers.
Supports 1 SATA-150 disk drive on each SATA connector
Speed up to 1.5Gb/sec or 3.0Gb/sec, complying with SATA 1.0 and SATA 2.0 specifications
NOTE: The faster rate of 3.0Gb/sec requires that both the hard drive and the motherboard support it. If one or the other does not support 3.0 Gb/sec, the system negotiates down to the slower 1.5 Gb/sec.
RAID
Not currently supported by HP PCs using this motherboard.
Onboard audio
Audio CODEC: ALC888
6 channel high-definition audio
Onboard LAN
10/100Mbps LAN PHY
PCI Realtek RTL8201N
Onboard USB
USB 2.0
Eight ports total
four connectors on back panel
additional headers on motherboard support four additional ports/devices
USB 2.0
NOTE: Some USB ports may not be available externally for customer use. For more information, see model specifications.
Back panel I/0
One PS/2 mouse port (green)
One PS/2 keyboard port (purple)
One VGA port
Tow USB 2.0
One RJ-45 networking port
Three Stereo-mini audio jacks for:
Line-in (light blue)
Line-out (lime)
Microphone-in (pink)
Internal connectors
One 24-pin ATX power connector
One 4-pin ATX power connector
One PATA connector
Two SATA connectors
One floppy drive connector
Two 12v fan connectors for CPU fan and PC fan
One 9-pin header for power button, reset button, power LED, and HDD LED
One line input connector (interrupts line input on back panel, Vista capable, requires matching front audio jack module)
One 9-pin audio header for headphone-out and microphone-in (yellow, Vista capable, requires matching front audio jack module)
Two USB headers supporting 4 additional USB 2.0 ports or devices
One Intel high-definition Audio/Modem Link (Not used by HP)
One jumper for resetting BIOS settings
One jumper to disable BIOS password checking
