MobTownTree
also picked that case because it still had ventilation through the window. Why dont more do this?
The 1100 is fine! IDK why the others are saying it's not good but it's fine, go ahead and get it.Ok, so here is what Im getting from you guys...
Video card is good
Motherboard is good
Case is good although a little "old"
Power supply is good
CPU cooler... I really liked this cooler. looks like it would look good with the other parts and it had good reviews. Anyone else think it would not be sufficient?
CPU Still going back and forth...
We on the same page?
As for the CPU, is gaming going to be the only thing you do? If so, get a 3570K. If you do video editing or anything else that is CPU intensive, get a 3770K.
What do you guys think of this one. Just found it. Looks pretty nice...?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139015
Also I am thinking I will go i5 and save some money. Mostly a gaming rig so that should hold me a couple/few years right?
That is basically the 300R but with a window and the 2 120MM meshes are on top of eachother. It has good airflow so if you want to go for it![]()
Trying to figure out if the black one also has a window. No pics. It must though right?
Yes aslong as its the same product. The color is different. The black is black (duhh) and the other one is Military Green
Shouldn't need it. For an SSD all you need is a SATA 6GB/s port, which all current boards have.Ok... and as far as the MSATA on the board... What size should I get. Surely it shouldnt be too large. I am having trouble finding information about it.
You get language packs and BitLocker drive encryption on top of everything which Home and Pro have to offer.On a side note....
Any gains if I were to go with windows 7 Ultimate?
I was going to get a SSD for a drive also maybe 240G but the Slot on the board is for caching. I am under the impression it is more of an additional RAM type deal. Is that wrong? I have the slot. If it will help at all I would like to put something in it.
