windows opening zip with java
turbodiesel
i recently uninstalled winRAR and then i downloaded a zip file for my minecraft server and its default tool to open ZIPs was java
how to i set it to windows default opening tool
thanks
I am using XP. So Rt Click on the File and choose Open With, Compressed Zipped Folders. Should be the same in other Windows versions.
Can also go into Folder Options, File Types, and find Zip, then change the File association to the same as above.
sorry i am using vista buisness
i managed to get it to open with open with then i searchead for windows explorer and used that
it stills works normally now apart from the icon is a little black sheet with a picture of windows explorer in the middle
how do i change that?
