I have upgraded my case for better cooling. The problem is that my motherboard only supports 3 fans and I have a total of 5. So is there any type of PCI card I can use that will add extended ports to connect my fans? Secondly, the front i/o panel on this case is usb 3.0. My motherboard only supports usb 2.0 and the case has a header for usb 3.0 so is there any PCI card I can use that will hook up the 19 pin header to in order to get the front usb ports working? Links to newegg.com or amazon would be greatly appreciated for the following 2 items.
I found the following item on amazon:
http://www.amazon.com/Silverstone-EC...+20+pin+header
Would this be the thing I need for the USB 3.0 ports to work?
