how to remove iexplorer
pjoseph
I am trying to uninstall internet explorer, but it is not listed in the add/remove programs list.
running windows 7
thanks
Control Panel > Programs and Features > Turn Windows Features on or off
Then just uncheck the Internet Explorer box.
Not a good idea. You need Explorer for updates. Critical and security.
Leave it there. Life will be easier with it if visiting Microsoft.
You don't need Internet Explorer to run updates with Vista and 7, only XP and previous operating systems.
