Mild Gaming Computer
dl13
Hey guys, I know I am going to get my butt chewed out by everyone on here saying I want to by a prebuilt Computer, but I am going to buy one. I just need some discussion with people here on which one I should buy. I really have wanted an intel processor, but I dont know whats different between an AMD and an intel processor. I am a new computer guy, but here are my choices, and also my Budget is a pretty sharp $750. So here are my choices so far.
http://configure.us.dell.com/dellstore/config.aspx?oc=dpcwxn1&c=us&l=en&s=dhs&cs=19&model_id=alienware-x51
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16883227408
I am only going to be playing games such as wow, Diablo III, minecraft, and TF2. If you guys can suggest me anything else that would be great. Thank you!
With the newegg one you will be much better!
take that...
at this point the difference between amd and intel is that intel cost a lot:P
the amd is cheaper and better so take that one and you will be really fine to play diablo and that stuff!:D
I would always go Intel, but of those two the AMD is better. The graphics will kick any advantage the intel processor will provide.
If I am correct one of Thoses is a dell? I have a dell at the moment, they seem pretty good but if you want to do any type of upgrading it'll be very hard! I think it's coz if you get dells stock parts, nothing else will fit.
Also the AMD looks better too :3
If you are looking to upgrade, just build your own. Its about as hard as a 200 piece lego set, and there are more tutorials on building a PCs than legos.
He isn't building one, he is buying one.
I agree that you should go with the AMD system.
