Noob question, but I'm looking to upgrade my current dual core cpu to quad or 8 core, but i was wondering if once i upgrade to a new cpu, will i need to buy another Windows 7 os?
No, you don't need to buy another copy of Windows. You may need to just reactivate it.
Nope, wondows is attatched to the motherboard not the processor, and what is your motherboard and current processor? i can check and tell you what it will support up to
Do you have OEM or retail version?
We don't know if he have OEM or retail. So I'm asking OP. OEM is attached to motherboard. Retail does not attached to motherboard but a law state that can't installing windows 7 more than one.
I have OEM. Thanks. I didn't know OEM and retail are different.
We don't know if he have OEM or retail. So I'm asking OP. OEM is attached to motherboard. Retail does not attached to motherboard but a law state that can't installing windows 7 more than one computer. once buy new computer, must delete windows OS on old computer then installing new computer.
Just because you're plan to upgrade your CPU, you don't need buying new windows 7 OEM.
It should have code on your motherboard. Plus, I'm not sure if you really have AM3+ or not.
You have AMD cpu right?
Doesn't matter what he has because he's only swapping his CPU, NOT his motherboard.
No i have intel processor, but that leads me to another question, can i upgrade from intel cpu to amd cpu?
Also, is amd known as a good brand?
Yes you would also need new RAM.
I found this combo of motherboard and cpu, what do you guys think?
http://us.ncix.com/products/?sku=69230&vpn=Z77A-G43&manufacture=MSI/MicroStar
http://us.ncix.com/products/?sku=70541&promoid=1027
Now i'm worried about the ram. I think i have ddr2 right now, would i have to upgrade to ddr3 for this new motherboard?
Check if you live near a microcenter, they got super deals on the 3570k and mobos
