Hello. I am building a computer for the first time. To lead off, this is what I'm going to be using it for:
As you can see from my usage, I do know something about how computers work, but I've never gotten much into hardware until now.
I also have some parts from my current computer that I can scrap too. (I keep a text document of it here
Also, my budge is about $800, but I might be able to push it a little.
Any suggestions? The main thing I'm currious about is the CPU but, of course, the other pieces of hardware are important too.
- 75% Software development
- 10% Games (Nothing too high end; Civ 4 at the most)
- 15% Internet communications (Something like Skype)
(Most of this is just the product information with a few parts swapped out. I'll probably start keeping a better list after this.)
Product number
- ER879AA
Introduction date
- 08-Mar-2006
Running System
- Windows 7 Home Premium
Base processor
PentiumD 930 (P) DC 3.0 GHz
800 MHz front side bus
Socket 775
Chipset
Intel 945P
Motherboard
Manufacturer: Asus
Motherboard Name: P5LP-LE
HP/Compaq motherboard name: Emery-UL8E
Memory
Component Attributes
Memory Installed 4 GB (4 x 1 GB)
Maximum allowed 4 GB* (4 x 1 GB)
Speed supported PC2-4200 MB/sec
Type 240 pin, DDR2 SDRAM
DIMM slots Four
Open DIMM slots Two
Hard drive
•300 GB SATA
•7200 rpm
16X DVD(+/-)R/RW RAM (+/-)R DL LightScribe drive
Port type Quantity
DVD-RAM 5X
DVD-R DL Write Once 4X
DVD+R DL Write Once 8X
DVD+R Write Once 16X
DVD+RW Rewritable 8X
DVD-R Write Once 16X
DVD-RW Rewritable 6X
DVD ROM Read 16X
CD-R Write Once 40X
CD-RW Rewritable 32X
CD-ROM Read 40X
DVD ROM
Maximum speed: 16X
Network Interface Card (NIC)
1 GB
Video Graphics
GeForce 7300LE
•64 MB DDR memory
•I/O Ports: VGA, Composite, S-Video
Television
TV tuner card with FM tuner
Sound/Audio
Integrated High Definition audio
•Realtek ALC 882 chipset
•Supports up to 8 audio channels
•Dolby Pro Logic II compatible
Network (LAN)
Integrated 10/100 Base-T networking interface
Supports the following cards:
- Compact Flash I
- Compact Flash II
- SmartMedia
- Memory Stick
- Memory Stick Pro
- MultiMediaCard
- Secure Digital (SD)
- Micro Drive
- XD Picture Card (xd = extreme digital)
I/O ports on the front panel (Only USB and Fire-wire are functional. It may be a driver issue)
Port type Quantity
9-in-1 (4 slot) One
1394 One
USB Two
Headphone One
Microphone One
Audio L-R One
S-video in One
Composite video in One
I/O ports on the back panel
Port type Quantity
PS2 (keyboard, mouse) Two (one each) (Both may need replacing soon)
Parallel One
USB Four
1394 One
LAN One
Audio (side speaker out,rear speaker out, center speaker out, line-in, line-out, microphone) One each
Slot type Quantity
PCI Three (One available)
PCI Express x16 One (None available)
DIMM Slots Four (Two available)
Bay type Quantity
5.25" external Two (None available)
3.5" internal One (None available)
Personal Media Drive One (One available)
Remote Control
- USB infrared remote and receiver
