So I was looking at the recommend specs for "The Elder Scrolls: Skyrim" and it says you should use a GTX 260. I have a 560, but the 260 costs significantly more than it (about $50 I think). From the little I've found, the 560 performs a bit better. But I'm not too sure because of the price difference (I assume the more expensive one performs better).
Thanks!
Thanks!
