Please tell me if this desktop will work!!!
CrazyKewlaid
Hey, I am buying a desktop, and i was wondering if someone could tell me if this will work with runescape, recording and editing, and rendering semi high quality videos, and playing games like diablo 3, etc. Here is the build. Also, can someone please tell me how much this would be worth?
motherboard: foxconn inferno katana gti lga 1156:
cpu: 2.8ghz i7-860 : <a
aftermarket cpu cooler: xigmatek gaia w/ blue LED fan :
ram: adata gaming series 4gb ddr3:
case: antec 300:
graphics card #1: bfg maxcore 55 gtx 260:
graphics card #2: gigabyte gts 250 :
power supply: rosewill 700w :
harddrive: 750gb western digital sata :
Good job :) Now, no, I wouldnt get it. Foxconn is, well, not a very good moterboard brand. Also, you cant SLi (run two nvidia graphics cards) 2 different graphics cards. Plus, the graphics cards are old. And, rosewill power supplys are not good, to say the least. They are not awful, but still have the chance of blowing up and taking the computer with it. What is your budget? I could whip up a build.
The board supports CF and SLI. Plus alot of Foxconn boards are pretty good. You would not belive how many motherboards and video cards are really made by foxconn. They are the biggest supplier of motherboard PCB and parts in the world.
Its a older setup, how much are they asking for it?
There is more than one way to set them up. Learn to know before you answer. You can use any Nvidia card with any other as a dedicated physics processor. The 260 with 250 physics would be a very well matched setup.
I know that Wolfe. But, a 260 is a pretty weak card by today's standArds. And, I do know Foxconn supply's a lot of pcb, but asus, etc has the good quality control over Foxconn.
Your covering, and as quoted your statement was you can not SLI two different cards. They are not in SLI, and your still covering. but w/e.
True, Foxconn make many motherboards and graphics cards and even stuff like mobile phones; but my 'self brand' Foxconn H55M-S died when I tried to update the BIOS. It was probably my fault it died, but it was a pretty poor/low-end board anyway. Maybe I didn't do it right or something; but if you can't understand Chinese then reading the manual is pretty hard. The English translation was just terrible.
I'd say the GTX 260 is still a fairly decent performer and that i7 is still going to be pretty good. If you can get that PC for cheap then it would be fine. If you're looking to build from scratch, it's an old and outdated build.
