*Unofficial* Smiles Benchmark ranking thread!
We are currently re-building this application to try and resolve some errors. The final version will be up and running soon! Stay tuned! :)
Will do! From the screenshots, it looks pretty impressive. I coded for 2 minutes once using 'Eclipse', I gave up after that. I never really understood it. What coding program would you recommend for a beginner?
like I use :P
VB, I'm a beginner too xD
you got skyper or something? Because I need someone to test my new version!:good:
Here, some of my pc's :P
1. SmileMan (intel core 2 Q8200 @ 2.33Ghz, 4gb ram 1333mhz, 14.869)
2. SmileMan (i7 920 @ 2.67Ghz, 4gb ram 1333mhz, 11.965)
updated :P
Hehe, here is my overclocked version :P
(I'm waiting for new cooler to overclock higher...)
SmileMan(i7 2600k @ 4.632Ghz, 16Gb Ram 1600mhz Kingstone hyperX, 7.4314)
UPDATE: Re-built SmileMan's app, corrected some errors and now it seems to be working! I have sent my builds of the program to SmileMan for his approval; but I've made both an x86 and an x64 version, so those of us with 64-bit systems can get much higher scores now.
Top window is 32-bit, bottom one is 64-bit. You can see the difference!
I used the rig in my sig to test this out on. :)
The revised version which I made using SmileMan's code and layout ideas can be downloaded from here.
All instructions included!
The new version which you linked to SmileMan also isn't working for me. The one I've made (^^download above) requires only .NET Framework 2.0. :)
ty man, it seems to be working on windows7/vista if the systems are dutch...
That was the problem, because I could use it on mine, my brothers and my moms pc (they are dutch). But not on my dads pc (english).
But I'll add it soon, when I got some updates in my code I'll send it to you to make it on an english VB.
I made it on an English VB. If you can make a continental one (German, Dutch, whatever language you speak) you can put it in the first post as a separate link for my English one.
So is my one working on Dutch systems or not?
