claptonman
Seems to be a issue with AMD processors. Got 93.35. Ran at the same speed as the first one. My score vs. Intels from the first one vs. this one, looks kinda off.
I got 91.36 with my 6100.
Plus sometime if overclock too high can cause to slow down.
...What?!
Yes all the AMD chips here should be much faster than the Q8300. It's odd that now our app is playing up on the AMD chips, and annoying too. :/ We are working on it and trying to correct it, give us a couple of days!MyCattMaxx said:This particular chip tested above the average Passmark rating when I tested it after I got it and it's rating is higher than the Q8300.
I got a 101.74 on my FX-4100 @ stock clock 3.6Ghz.
A reboot would have helped considering everthing I have loaded up, but something is definitely not right with the test for AMD.
Passmark might not be stable benchmark but it is odd. For one thing i can tell is Windows 7 does not recognizes that well. Here is link that might will be helpful.
http://www.techpowerup.com/158534/New-Windows-7-Bulldozer-Patches-Available..html
One question, how many thread in task manager on your computer?
Well he has an FX-4100 so I assume 4 cores w/ 4 threads?
I think I know what's up with the AMD chips. There's a bit of code which we added which I bet if we remove will give the AMD chips better scores. I'll remove it tomorrow and update.
It'd be better to have one version which works equally on both platforms because then we can compare the performance of various chips more fairly.Maybe make it Intel and AMD verison? Like if game is made for intel, not AMD. It would be slow on AMD.
Unlocking two extra cores isn't going to do a lot of difference as this is only really threaded for 4 cores. :/ Sorry.i unlocked my 960t and at 3.4 or so ghz it pulled a 103, and when it was locked at 3.4 it was a 105, wtf?
