Removing the door
Hey i am sure alot of yours have seen the cases that are for sale with names like venus, saturn, mars and orion cases. But what i was wondering is on the orion case there is a door on the front that opens and closes. I dont want it there i like the look of the case. But can you remove the door without damaging the rest of the case ?
Here is a link for the case i like !
http://www.ebay.co.uk/itm/NEW-CIT-O...ponents_RL&hash=item20c5dba853#ht_3110wt_1031
It can sometimes be hard to remove the door depending on which case you use. I'd recommend you stay away from these cases anyway because although they look kinda cool they're pretty poor cases (sharp edges and no cable management features). I'd spend a bit more and get something like this http://www.ebay.co.uk/itm/Zalman-Z1...ponents_RL&hash=item19d2ae2ba3#ht_7485wt_1396 that would be a much better case. That case doesn't have a door either. :) Doors on cases can be a bit annoying at times.
